Interest in group buy on a new cold air intake
4DRHTRD
While I'm having hot pipes done I could also prototype a new cold air intake. The intake would replace the front and rear tubes and have a separate tube per turbo into an air filter with separate holes for each tube.
It would look something like this but I plan on having aluminum pipe ran down to the front turbo and rear turbo, no rubber tubing.
Although the idea will be based off this design it probably won't look much like it except for where the factory tubes have to tie into the factory bits.
You would still need rubber tubing to connect the pipes to the turbos..no? That's the only rubber tubing on that kit. I know BPD was trying to do the right thing asking Kirk...but that's really Henneseys kit
I meant the long tubing piece, you will have to have some silicone couplers
Sent from my phone with lots of misspelled words...
With the data I've seen lately indicating CAI's being basically useless, I'd like to see before/after dynos. If it make any decent power, I'd be in.
