Knock PID!!!!
4DRHTRD
Somebody please configure Torque for this PID and see if you can monitor knock.
Manufacture ID: OEM_FORD
COM Level ID: CommLevel_ISO 14229
Comm Type ID: CAN_COMM
Category: Spark
16 Char Name: Knock Sensor
Description: Knock Sensor Retard
Address: 0x3ec
Address size: 2
Units: Degrees
Data Type: Int16
Binary Point: 9
Multiplier: 1
How to add the PID
[list type=decimal]
[*]Open Torque and go to “Settings” (usually by pressing the bottom left key [looks like an upside down box] on the phone / tablet and then selecting Settings).
[*]Scroll down in the settings list and click “Manage extra PIDs/Sensors”
[*]Press the Menu button again (looks like upside down box) and press “Add custom PID”
[*]Press “OK” to agree.
[*]Fill out the appropriate information from the information above.
[/list]
I have had that loaded up in Torque for some time.  I documented it quite a bit over on the "other" forum although I have to admit it didn't generate much discussion.  I can confirm that you can get data back on that PID (In Torque you do need to type a 2203EC because it needs to know the mode (which is 22 in this case).  I could never really figure out the formula though - perhaps someone on here could offer some assistance...here are my observations.
First it is normally "0" at idle.  If you start to accelerate lightly it jumps to 255 and starts decrementing by 1...almost like a "hey I'm active and counting down".  If you floor it - it seems to go back to zero and will occasionally count a 1 or 2 - which I always assumed "might" be knock but I could never really tell.  If I try and compare it to my SCT it always appeared that reading this PID unscaled seemed to be a 4 times the value of the SCT.  I do see above it has an address size of 16 which I assume is two bytes so the Torque formula probably needs an "A" and a "B" parameter in the formula.  I am only using the "A" parameter.
Does anyone know what "binary point 9" means??  "Multiplier of 1" I assume means no scaling value is required.
Thank you very much for at least confirming this is an actual knock PID. (Was never 100% positive) but I still can't really get a value I know is right.
Okay I guess that makes sense.  What does it mean in relation to the PID though?  Does it factor in to the equation somehow?
I got in a huge fight with an sct engineer over email discussing this. He kept telling me to use tsx or live link, I told him just help me with the knock pid. It didn't end well, another employee apologized for them but still said use sct crapware instead of just telling me the calculation they use
Sent from my phone with lots of misspelled words...
That stinks.  Props for trying though.  I can understand them maybe not wanting to share the PID but not the equation.  As for Live Link I would use it if they would invest some resources in to making it useable program.
I will keep trying to make sense of it.  I know using Forscan there is a PID called knock degree timing (or something similar) and it goes positive and negative so if this is the same PID it might be using a two's complement or need to mask some bits or something...if only it were obvious.  Torque can handle all of those things but guessing at the equation isn't easy (at least for me).
Anybody try to post a request for help with the formula to Ian?  He is pretty prompt with his responses to queries on the Torque forum.
I offered him cash for the nested alert previously.
If you guys can get it to work that would be awesome.
I also need to figure out how to match my instrument cluster with Torque, just installed my tablet with a pretty cool little dash mount that Troy told me about, cheap and awesome.
[/quote]
[/quote]
Love to see a pic of your new mount. I'm now also using a new inexpensive mount that I like better than all my previous home made attempts. Also I finally whipped the charging issues that have plagued me. Victory feels great.
Just posted it. :)
painterpatt said:
So did you get it to work 4DRHTRD? I saw the pic in the mount thread and it says knock on the screen?
Yes it kind of works. If you go WOT it will zero out the increase if you are seeing knock. Mine sits at zero once I got WOT, at part throttle it goes to 254 and starts counting down.
painterpatt said:
oook, lol. I still hear nothing (knock) from mine but it shows on the sct, still gotta try laptop
That means the computers doing its job!
If it shows knock it should pull out timing. You can see knock pretty easily by watching timing. If it drops out suddenly well there you go... knocking...
4DR are you sure you're not looking at the knock sensor PID that checks for wiring faults? I'll have to look up the exact data it sends, but it does something similar to that but doesn't accurately show knock. I'll letchya know if I find something different.
