ZSHO said:There is one Drain on each corner Towards the front side of the sunroof. Check to see the drains are obstructed with Dirt Buildup. Is there any water on the passenfer side footwell! Z
SHOdded said:no ... could still be from blocked drains or less likely, leaky sunroof.
I dont have the drain schematics. Im guessing inside your door jams,under the seal. ZTopherSho said:SHOdded said:no ... could still be from blocked drains or less likely, leaky sunroof.
Your 2017 post may have solved it, I still need to check the drains Z point me towards.
Reset is putting the Moon roof in the right spot now.
I'm 99% confident that was the issue, in my driveway i *think* my car body was flexed enough the not fully sealed moon roof was dribbling NOT into the drain pan in the back of the moon roof assembly, but along the roof\body at a angle (my driveway tilts about 15' UPWARD and about 7-8' DOWN to the RIGHT on the passenger side.. I think it explains the stain not being wider in the back near the glass, if the rear windshield was leaking the capillary action would spread outward evenly from that point and not just kind of creep forward along the rear passenger door and upwards.
I bet it has been this way since the engine swap .. just never noticed it![]()
Onto drains ... Z where would these drains exit? i want to inject water into the hole and monitor dripage.. I assume it will hit the floor of my garage somewhere![]()
ZSHO said:I dont have the drain schematics. Im guessing inside your door jams,under the seal. Z
ZSHO said:It could be a faulty sunroof Holder control rod or bracket IMO.. Based on the video the sunroof is collapsing with no support. Z
Ford Part No.: 7W1Z-5454022-A
Holder - Control Rod
https://www.fordpartsgiant.com/parts/ford-holder-control-rod_7w1z-5454022-a.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=body_and_paint/sliding_roof_mechanism_and_controls,,%3C54022
https://www.fordpartsgiant.com/Page_Product/PartDetail.aspx?Vin=1FAHP2KT5DG183206&Filter=()&SubCategoryUrl=body_and_paint%2fsliding_roof_mechanism_and_controls&Diagram=&PartNumbers=
True indeed MANU! Time for some Spring cleaning. ZSHOdded said:Drain hose routing 2014
http://www.nicksmustangranch.com/Service_Manuals/2014/2014_Taurus/Service%20Manual.htm
On the Edge, there are drain holes in the doors under the weatherstripping that lines the outside of the door panel. I am guessing same for the SHO.
