So i was changing the oil today on my 2010 mks and i noticed some fluid leaking in the passenger side front of the car. It's got a slight brown/orange tint to it, so i'm assuming it's brake fluid. That's the only thing i can think of that resembled what this looked like. My coolant is specialty green, so it's not coolant. It wasn't oil.
Also, what's in front of the radiator starting from the front of the car? Is it the intercooler then the condensor or the condensor and then the intercooler? Because whatever is in front, the whole left side was covered in whatever this was. You can see it directly through the front grill of the car on the passenger side. Do the brake lines even run that far in front of the car? Kind of hard to tell.
Brake fluid level was a little low, but still between full and low, so nothing too out of the ordinary. Just did the brakes and a brake flush not too long ago. Front passenger calipers were clean and dry. I filled it up and will be keeping an eye on the fluid level over the next couple days.
Any ideas?
Any ideas?
