jimmyducati
I have had this problem since I bought the car 2 years ago and have yet to find a remedy for it. Under hard acceleration I immediately get a CEL with strong bucking of the engine and the A/C stops blowing cold. The CEL stays on for 1-2 minutes and when I try to press on the gas the bucking comes back while the light is on. Using the torque app, the CEL is cylinder #6, everytime.
So far I have replaced all of the spark plugs with Iridium NGK plugs all gapped to .030, and I have swapped every coil to another cylinder hoping the misfire would follow a faulty coil. I have also ensured that all of the cheap ass rubber on the tip of the coil and around the neck of the coil is in new condition and have replaced a few that had imperfections. I have also checked and double wrapped the knock sensor wire that runs along the front of the engine that is known to wear and short out.
The only item on each cylinder I have not touched are the injectors. I had an appointment at the local dealer this morning and after driving the car aggressivly we were able to get the CEL in short time, the tech said it was again cylinder 6 misfire, but he claimed the code flagged the coil.. I protested stating that I have swapped all of the coils around and the CEL is always on #6, he maintained that the injector cannot cause a misfire...
SOO.... Name all the possible causes of a cylinder misfire on an ecoboost engine!
