LMS Remote Eblended Tunes!
StealBlueSHO
Administrator
Staff member
So on shoforum Cody from LMS posted they do remote eblended tunes if you have their HPFP.... so naturally I called in to verify this information... and sure enough LMS DOES DO REMOTE TUNING for E85 Blends. I believe they said up to E45 on stock injectors..
I asked him to let me know which blends they recommend so I can put in a tune request.. SUPER FREAKING STOKED ABOUT THIS!!!
Obviously.. I report back with my findings.. loving this HPFP more and more...
I just want to know if they add a flex fuel sensor in their installs, or if they have a tune option for it, because they were claiming to offer flex fuel tunes with their HPFP a while back while it was in development
You can always call them. Cody, Anthony, and Dave have always been very informative when I call. I am sure they will know the answer.
Quick update...
According to Cody who placed a call into the calibrators, they can tune up-to 42.5% Ethanol blends in the Firestorm HPFP.
I did go ahead and put into a tune request for an E30 blend as that’s generally where you start to see the most benefits from what I understand...
Cody said it will take a few days as they don’t have the tunes built yet for all the strategies....
Will update again as soon as I get it loaded!!!
Have I mentioned I am STOKED!!!!
Testing here... E31 in the tank now.... perfect fuel pressure... not even a dip..... fuel trims are acceptable (+10% average)
Still waiting on the optimized tune... but this pump is laughing at E30....
So I got my E30 blended tune from LMS. Datalogging shows NO increase in spark or boost which is a bummer. However there were changes made to the fueling as the fuel trims are much cleaner.
Livernois Motorsports said:
Hows the car feel overall?
Overall the car runs like a top! Even the E30 tune is smooth as silk. And you guys turned the E tune around much faster than expected.  Thank you for that! Now let’s dial it up a notch!
Cool glad your happy with the tunes we will be here for anything else you need!
I need more powah!
To be fair with this, I am the first recipient of a remote tuned E mix from them. And while I don’t “see” any changes in power, I must remind myself that LMS always errors on the side of caution. I’m sure that they will step it up once they do a couple more with success, or if I bug them a bit ;-)
Similar to my remote meth tune on my 2010... the first tune they provided was tame but the follow up tune really made a difference.
This E30 tune really does bring the fueling inline with an E30 mix which is very important. The trims are within +/- 5% which is really good. Before the tune I was at +15% for reference. They also addressed lambase to address the difference in stoich which is important. Overall the tune is really really smooth and runs well.
I should know better than to expect a tuner to throw the kitchen sink in off the bat.. baby steps when treading new territory with a remote E tune with the bigger pumps.
There are only a handful of guys running the bigger pumps and only a couple like myself getting them remotely tuned. So it’s still new territory for any tuner.
Thanks LMS for the quick turn around on the tune, and again, Cody and Anthony for answering my questions!
I am looking forward to seeing if there is more power we can squeeze out of this (safely).
Just an update....
I noticed besides the fueling fix they also appear to have adjusted the IAT spark compensation as well...
There is more than I suspected changed in this tune... still happy!
Sick of the updates yet? Well I have another one....
I have been running the E30 blended tune for a bit and had to switch to the 93 V11 HPFP tune on the ride back from Carlisle due to stopping somewhere that didn't have E85...
There is a difference in the seat of pants feel between the two tunes. The E30 sure does feel like it pulls harder.. after loading the 93 it just didn't have the response of the E30...
Although the datalogs looks very similar besides the fueling, there is something there taking advantage of the extra Ethanol. Feels like I am chasing my tail again similarly to the 4+X Meth and 4+X 93 tunes.. Didn't see any difference in spark or boost but there is something else going on. Maybe those extra tables that LMS has access too? or I am just not logging the right information.
Kudos to LME.. always seem to surprise me!
I don’t know about extra tables! You are reaching hard!...power is boost and spark...would you be satisfied if the answer was simply that the ethanol is always allowing max allowed spark from the knock sensors and perhaps more spark being allowed?
Maybe thats just it.. But can you not gain power by leaning out the mixture? I know they have made some adjustments to the fueling and its not commanding as rich a mixture. That said, the stoich is changed with E30... I suppose I could look it up to find out what the AFR is targeting per lambda with stoich at E30... it may or may not be a slightly leaner mix.. BUT there is a difference in how the car feel.. as you stated.. it could simply be that the knock sensor is able to add maximum amount of allowable spark with the E blend.
I have seen 1 KR or so with the 93 V11 tune.. but none with the E30 tune.
Yea you can gain power by leaning out the mix...I think I use 12.95 for stoic for e30...but I can get myself confused becaus even if you lean out the commander lambda you are still running richer overall because of the stoic lol...so I don’t know if it’s leaner or richer ...guess it depends if you are using lambda or air fuel ratio lol
There is also cam timing
