LMS tune updates
68_GT
thought is might be good to start a thread to discuss any updates LMS customer come across so we can keep each ther updated here on any new updates.
My latest tune adjustment was uploaded on 2-20-14.
For my 2013 SHO
This was a:
91V7CW and a 93V7CW. the "CW" is for cold weather fuels which initially eliminated my higer rpm hesitations at wide open throttle. That is until I had to put in 92 octane fuel then I felt but not near what is was before. Hopefully the lower octane is all that caused it. This tune included a 170*Tstat which I havne't put in yet but I'll get to it ASAP. No changes evident with the stok stat still in. Of course I only loaded the 93 tune.
LMS e-mail info compliation from Anthony about it....
The CW is our latest tune revision which is improved performance for cold weather as well which some customers were reporting a stutter at wide open throttle at high rpm.  The CW tunes have only been necessary for cold weather so most of our customers plan on changing back the the v7 for the warmer months. I will get the 3 bar tune set up for you but I see you have had both with and with out cw and both with and with out thermostat tunes.The 3 bar map sensor allows for greater tuning capabilities due to the vehicle being able to recognize boost higher than 14.5 psi.  It is also a requirement for running methanol injection or upgraded turbos. Your vehicle may allow for more boost if it sees fit. The vehicles base boost off of torque on the ecoboost platform so every vehicle can vary depending on climate, barometric pressure and so on.
On 3-3-14 I got the following tune updated to the server but haven't had a chance to mess with it yet.
93V7CW-170*3bar-3barMAP
93V7-170*stat-3barMAP
I'll run the 93CW170-3bar for now and the non CW in the warmer months.
LMS info from Anthony
I have set you up with a 93v7  170 3 BAR and also the cold weather version 93v7p CW 170 3 BAR.  We are in the development stages on any future upgrades at this time such as fuel system upgrades
all that being said if my SHO was making over 14.5 PSI with a 2 bar what does it do ? I mean other than not recognize the added boost ? seems like that would be a lean condition if the ECU doesn't recognize the added boost and therefore doesn't add more fuel ??? or it bleeds off the boost in excess to 14.5 ??
guess I'll just have to put in my 3bar MAP and loade the tune to see if there's any performace gains with a 3bar MAP and 3bar tune on 93 w/o meth.
I'm also interested in knowing what happens if additional boost is produced without a 3-bar MAP. My greatest fear is a lean condition.
I won't be able to tell if my 3 Bar tune allows for more boost until it warms up here.  The colder, condensed air here lowers my requirement for boost.  But, I can tell you it runs and idles extremely well.
DJE624 said:
I won't be able to tell if my 3 Bar allows for more boost until it warms up here.  The colder, condensed air here lowers my requirement for boost.  But, I can tell you it runs and idles extremely well.
how does that work ? oddly I dont notice any performance difference in my SHO in 32* weather vs +80*. I guess its only going to let you make a certain power level regardless of outside temps ??????? Does the ECU throttle back power if the incomming air temps are cold ?
Our turbos are controlled by torque demand.  There are other variables (that I don't completely understand) but one of them is that colder, condensed air requires less boost for the same torque.  My peak boost has changed from over 14 in the summer (80-90+) to 11 in near zero weather.  There is also something about winter fuel and efficiency in there too.
Glad to hear what boost you are getting in this weather Dave. Me too!  I was starting to feel disadvantaged.  Right after changing my plugs, I was reading slightly higher boost, but the car was running bad....like hitting a rev limiter at the top of the shifts. Turns out I had a vacuum sensor leak causing an over boost condition that the ECU dealt with by pulling something.....don't know what. Now my boost is around 11.25 and the car never has run better. I will hopefully see some higher boost numbers this summer. Sorry for the thread jack but I couldn't resist.
OK my next mod is to request more demand for torque in my tune :)
I wondered why my car felt the same in all temps. Darn you Ford ! it should just add more fuel for the colder air intake temps and let us pick up 30-40 hp in cold air for the winter months !
Glad to hear it Larry!  I was telling Tom about it but he's in hot weather and wondered what was wrong.  I'm glad I'm not the only one effected with DB-diminish boost. :clown:
BTW, when I went out last night for a run after putting the stock box back in, I had 11 psi peak.  It ran like a champ.  Launched at 2K, spun like mad (like a couple seconds) on the salt and still pulled a 5 flat to 60. I'm sure on good pavement, I'll be looking at low to mid 4's.
It does pick up alittle going down from 90+ to say 50 degrees.  But once you get really cold, that's it.  Car still performs. Just not over performs.  :clown:
I am sorry to jump off topic, too, but I always thought MORE boost was generated when the air was cold.  I am glad to learn otherwise.  I have no way at present to measure boost so I will defer to you guys who can actually measure it.  It seems to me that my car runs much stronger when the temps are cold, though.  Maybe that is my imagination.
Dave... Don't you think your comparison between aftermarket CAI and the OEM box in a real life "on the street" test also shows, like the comparison of no box vs OEM box we did on the dyno, that air flow intake is not a point of performance restriction for the SHO... At least with factory boost tables functioning in the ECU?
I have always been a proponent of the stock box.  I just put the Typhoon on cause it was discounted  and looked cool.  The stock box flows as much as needed and the heat sink factor may be to it's advantage.  But, the reason I swapped back is that the rasp of the turbos spooling was annoying.  Like your test Tom, I think the stock box is the next best thing to a wide open intake.  (I should mention here that I do run the K&N panel.)
DJE624 said:
Now, I must apologize to 68 GT for helping jack his thread.
my thread :nuclear:
it's all good. Nice info seems like the tune would change that so you can have more power in cooler temps. I mean why wouldn' it ?
68_GT said:
my thread :nuclear:
Apologies from me too 68_GT… sorry about the jack.
To respond… I think Dave has the idea.  If more torque is called for by the ECU (from a tune modifying the table) I think it should.. The ECU would need to allow more torque to utilize the colder denser air optimally.  Another example of conservative OEM tuning the SHO is assembled with ...I think.
If there is a control method built into the OE tune tables which limit boost based on a variable such as temp (air density), then I would surmise that as being a failsafe or protective measure of sorts.
Anyway, if I understand correctly, Livernois has built a tune for the following configuration -
93 octane, 170tstat, 3 bar, no meth
Is that correct? So, what, I assume the only thing that is manipulated is more boost?
Also, is Livernois dabbling at all in tuning for E? I mean, even for mild blends, such as E20.
I'm ignorant to the facts, but I believe I saw mention of the 13+ fuel system, namely the HPFP being able to deliver more fuel than previous models. When is it that the injectors are no longer able to keep up? 4DR also mentioned the in-tank pump being a restriction...
Yes, LMS has that tune.  The 170 part of the tune turns the fans on earlier.  I don't think the 3 bar tune adds more boost but, it enables the ECU to read boosts higher than 14.5  I am not certain about  the details either but, I assume the signal from the 3 bar may allow the ECU to adjust things like the timing, fuel mixture and other variables to get the most out of the 3.5 especially at boosts over 14.5  In a lot of cases our tunes may be going over 14.5 but w/o a 3 Bar, the ECU wouldn't know or react.
My new tunes include the 3bar and no meth. And this ^^^^ was the same explanation LMS gave me..
Not more boost but ability for the ecu to read the higher levels..
