Lubegard Fuel System Booster - Deal on Amazon
Moderator
Staff member
Supposedly works great for DGI.  If you want to try it out:
http://www.amazon.com/gp/product/B00BZMQSVC/
Product info here:
http://www.lubegard.com/C-1027/Fuel+System+Booster
Thanks - I am game to try it. I do the 3M complete fuel system tune up yearly, but can't hurt to do this too. I bought 4 bottles to get free shipping (our Enclave is DI also - so that's two RX per vehicle). Thanks for the links.
Thanks for sharing. Think I'll give it a try in a couple of my vehicles.
But, aside from maybe piston tops and possibly injectors, what additional benefit does it pose to a DI system?
*EDIT
Just placed an order. Yup, a buck eighty. But apperently isn't expected to ship for 3 or 4 weeks? O_o
Honestly don't know.  I don't expect it will keep the backside of the valves clean, but someone with a boroscope can verify ;)
SHOdded said:
Did it allow you the coupon 4X in 1 order?  Price did drop $1.20 since I posted, nice!
something tells me I did not do it right. I Did not see a coupon. I thought the good price was $9.99 each. Lol no biggie.
I was poking around some of their other additives. They've got a suit of goodies. SHOdded, do you have experience with their other products? I see nothing but glowing reviews, notably on bobistheoilguy.
Whoops!  Looks like they yanked it, sorry ... :(  I hope many on this forum were able to take advantage!
A while ago before i installed my PPE CATTED DP'S purchased about two dozen bottles of stp octane booster on clearance at Target for 1.18 each,learned that the magority of octane boosters have a chemical called MMT IN IT as mostly of us are aware of,the chemical is not compliant with cats and can do more harm then good,during combustion manganese vapor is then deposited in your plugs then in your cats and then could obstruct exhaust flow and impede the ability of the cats to do its job and pass emmissions,would better use the E85 like most of us benefit from.
This is not an octane booster, rather a 3-in-one fuel cleaning/stabilizing product.  I don't believe it has MMT in it, rather PEA:
Section 3: COMPOSITION / INFORMATION ON INGREDIENTS
[Key: Ingredient - CAS # - Wt. %]
Light aromatic solvent naphtha (petroleum) - 64742-95-6 > 60
Polyolefin alkyl phenol alkyl amine -(Proprietary) > 5
Solvent naphtha (petroleum), heavy aromatic - 64742-94-5 > 1
Section 9: PHYSICAL AND CHEMICAL PROPERTIES
Appearance: Clear.
Color: Amber.
Odor: Aromatic hydrocarbon.
Odor Threshold: Not available.
Physical State: Liquid.
pH: Not applicable.
Viscosity: 16 cP @ 40 °C (104 °F)
Freezing Point: Not available.
Boiling Point: Not available.
Flash Point (PMCC): > 62 °C (> 144 °F)
Evaporation Rate: Not available.
Lower Flammability Limit: Not available.
Upper Flammability Limit: Not available.
Vapor Pressure: Not available.
Vapor Density: Not available.
Specific Gravity: 0.85
Solubility in Water: Insoluble.
Coefficient of Water/Oil Distribution: Not available.
Auto-ignition Temperature: Not available.
Percent Volatile, wt. %: Not available.
VOC content, wt. %: Not available
Appearance: Clear.
Color: Amber.
pH: Not applicable.
-MANU YOU THE MAN,just like to take precaution pertaining to various and harmful chemicals added to the fuel system and then exposed to the environment,thank you. :)
ZSHO said:
... just like to take precaution pertaining to various and harmful chemicals added to the fuel system and then exposed to the environment,thank you. :)
A wise precaution, always good to keep in the back of the mind :)
Some Octane Booster MSDS sheets for your reading pleasure ...
