korb419 said:Spartn27 you running meth?
Not yet, I was planning on it though might wait until spring.
Do you know the part number for the ngk? Wonder if anyone's tired any other type of performance plug.SHOdded said:If the plugs are indeed stock/stock gap, that will NOT work with a tune. You need to have at the very least, plug gap set to 0.030 (I believe Torrie likes 0.028) and plugs changed regularly depending on how fast this gap grows. The NGKs from Torrie or the Motorcraft SP534 plugs should work fine as replacements. So add that to the work that needs doing before the MKS is able to run smoothly again.
korb419 said:What tune are you using torries? And what type of tune? Mines 93 octane with smooth shifting-mild tune then the boost tune is where I seem to have issues and hiccups in the power delivery
Running a 91/3bar/170°/Meth Torrie tune. No issues for me so I'm sure yours will get worked out. Plugs need to be set first for sure.korb419 said:Wasinger what tune you running?
Is the smaller gap recommended for when using meth, or is this something we're just now concluding after getting some time in on these ecoboost.SHO-TYM said:I have every bolt on part for the SHO including Meth injection. I purchased the motocraft plugs gapped at .030, and when spraying meth, it seems to be loosing spark, so I am having vehicle picked up by Livernois and transported to their facitlity to put new plugs in and tighten the gap, and dyno tune the meth kit. I would def. recommend putting the gap at .028. You may lose some MPG..... but the performance is what will improve.
korb419 said:MDesign what you think your 0-60 is ?
