StinkinLinkin13
Ok. Been a lil while since I posted. Been working with Brad for several months. Had several issues now and then in what seems like every area... Which yes is frustrating at times but also great because you are at least aware of issues and can address them instead of blind canned tunes.
Anyhow. Here's the current issue that has us a little perplexed. I'm now running E-40 tune plus 100% VP Meth Alky controls kit with M10 nozzle... According to Brad everything looks good fuel wise with no knock retard and stft show meth is being injected and at a percentage Brad feels good about but COOLING is minimal to non-existent at IAT2. It's hot down here but according to him the cooling is less than he's used to seeing/expected.
Quote
"Your short term fuels look good like you are getting the right amount of meth. I generally like to see them somewhere in the xxx range...So its weird that you are there but I don't see the cooling...On the 3rd gear pulls I see some cooling...Not as much as I expect but then on one of the multigear pulls you had around a 40 degree increase over ambient. I don't see how that is possible...Unless the meth isn't atomizing really well. You have fuel pressure, and stft's show meth is there but no cooling?"
Just fyi this Is approximately my 3rd - 4th logs with meth and the results have been consistent. Any thoughts ideas suggestions shoot away... I am gonna have the initial come on a little sooner and the progression a little steeper but as you can read he's seeing the meth in the stft but without much if any cooling... I have my EPP Hot Pipes and the nozzle drilled just after the elbow facing up. Seems to be a common install point. Thanks in advance..
Quote
