Had the stage 2 snow performance kit laying around, finally warmed up enough so I took on the dubious task of installing this all by myself. It was a really fun project. Took me around 4 days of working 5-6 hours a day.. This was very slow and easy work though, didn't rush anything. A lot of time was wasted in parts runs, brain storming, and other miscellaneous things. I added some extra time by relocating a windshield washer tank and running all the wires/hoses for it. Was going to skip it but I figured I may as well do the best job I can!
I was going to do an install guide just to cover some issues I faced that weren't mentioned, and I still might. I'll have to see if I have enough pictures!
Here is a few pictures of my install though.
I installed the pump right next to the windshield washer tank, which I'm going to use as my methanol tank as most people do.
Here is a better picture with hoses.
I used the provided tank from snow performance and used it as my windshield washer tank. I installed on the driver side (exact opposite of the OEM windshield tank). This picture doesn't show it, but I brought the pump over to this side too, ran wire across to power it from the original source, relocated and added some hose from the pump to the spray nozzles for the windshield. For now I just have a hose ran up next to the battery to fill with a plug, but I am going to add a small fill reservoir and probably attach it to my airaid intake box. It should be pretty clean once it's all done.
I installed and mounted the progressive control box inside my glove box (have to take a picture of it yet). Ran a few wires and hose through the firewall. The nice thing though is that when I get around to ordering gauges, I can easily tap into it for my boost gauge.
Also, I ordered a 5 gallon barrel of methanol.. Came in the mail today! Spendy stuff to order online, but unfortunately no speed shops even close to me so it was my only option to run my 80/20 mixture. Didn't want to experiment with washer fluid and heet either.
Unfortunately after all these nice days we got in northern Minnesota, it decided to randomly snow quite a bit today.. So no chance to run the methanol today and datalog.. Oh well. Super excited though.
