So I grabbed my MSD DH and setup some pids to go and log the Flex. I've gotten on this thing a few times, but tonight I got on it and heard audible knock followed by a misfire on cylinder #3. I drove around until it got out of limp mode and eased into it. No issues. Got on it a couple times with no issues. Hit it hard one more time and got a code for random misfire. I will swap out the plugs this weekend and move the coil on #3 to another cylinder, but I'm worried that this is fuel related. I will check with my powertrain warranty to see if injectors are covered, but if not, how hard is it to replace one?
Also, I saw 9psi at WOT and my WB EQ ratios were at .75 - .8 the times when there was no knock / misfire. They are right around 1.0 while cruise. Am I really reading 18-19:1 AFR? or am I supposed to multiply EQ ratio by stoic and not divide? If that were the case I'd be 11.0 - 11.7.
