jimmyducati
So I've been getting the cylinder 6 misfire virtually every time I accelerate hard, and this weekend it started to show the #1 bank upstream O2 sensor fault (second one in 10k miles, different sensor thought)! I plugged up torque and watched the fuel system status and after a hard acceleration it would show "open loop due to system failure" for a few minutes and would begin its typical stumbling, then eventually I would get the #6 misfire. It would generally happen like that, but sometimes id get one or the other. If the injector is causing that cylinder to run very rich, I guess it could shorten the lifespan of an O2 sensor, no? Not even sure it the #1 upstream is in line with the #6 cylinder..
