Need a volunteer near Southern WI for fuel system plug and play prototype
I live in romeo MI. ..southeast MI about an hour and a half from the southern border...sounds like this would be fun to check out....are there any issues you're expecting to pop up during testing and would my current tune need updating to take advantage of this extra fuel...should I have a setup capable of data logging...thx
4DRHTRD said:
The benefits of this fuel system will be:
The ability to run E50 on stock turbos and tune
The ability to support more power on upgraded turbos with 93 octane - if you ran out of fuel before this will give you approximately 30% more fuel headroom.
Are you describing a completely parallel fuel delivery system?
E50 is not in my area (it is on military bases I cannot access), so my interest would be any benefits to pump gas.  I think anything we can incorporate at the stock tune level, only makes the tune that much more of a benefit.
No it is a replacement pair of fuel pumps that go in the gas tank (accessible through floor under passenger seat) and a new feed line to the engine bay. You'll also install a fuel pressure regulator in the engine bay and use the factory line as a return line.By increasing base pressure and boost referencing the fuel pressure regulator you increase the fuel delivered to the DI pump and thus the output.
E50 is a mix of 1/2 E85 and 1/2 E10 91 or 93 octane gas
How is this going? I would love to be able to get more power out of my car without methanol. Any plans to make a system that can handle even more power? I would like to keep my car running just 93 pump gas or e85.
