Need advise on rotors
mike2225
Hey all, Im looking to replace all my rotors for my 2015 SHO with PP. I want to stick with the stock PP pads and an aftermarket oem style rotor, Ive had bad luck with drilled and slotted rotors warping or cracking with my previous cars ..After a little research it seems like most people are using Powerstop or EBC rotors.. Can anyone help me decide which rotor would be better for me
Nothing has been proven to outperform or outlast stocks. That's what I would go with. If you just want rotors that look pretty, but whichever looks best to your eye.
So historically if you want drilled/slotted for the eye candy AND performance you will need to go with a high quality setup like EBC or Brembo(who doesn't make anything for our cars that are D/S).
For best performance the OEM vented rotors will outlast and outperform most of the D/S setups.
The Powerstop D/S that were on my 2010 non-pp had pretty good surface cracking after a few back to back track days.
Thanks for the replies, I had the same issues with my drilled and slotted rotors on my evo. I kept cracking the so called upgraded rotors.. I ended up replacing the pads and rotors with all oem parts for the SHO, its been about 2 weeks now and brakes have been perfect
upgrading the pads will be most effective, as long as the rotors are high carbon steel, GD3000 or 3500.
Police pads from Raybestos or Bendix should be at least as good if not better than PP pads.  But yeah PP pads are rock solid.
I like the response from EBC Orangestuff on my Edge, these pads are rated higher than Yellowstuff.  It WILL stop your vehicle.
You can also contact Todd Cook at tceperformance.com or Brandon Dubose at BDR Racing
BDR Racing:  Brandon uses his personal profile for stuff on Facebook and bdr_racing_development on ig
Some results on an Edge attached
