Need help! Livelink 'The following items failed to setup'
Wilson
Got my updated 3 bar tune from Torrie a few days ago (thank you sir!), however I've been unable to do any data logging.  I tried to use a preconfigured config file sent to me by another member, containing all the items I'd need to datalog.  When I go to start logging however, I get this:
Just to rule out the config file, I started from scratch in Livelink selecting only those items manually, but still get the same error.  Does anyone out there have an idea as to what's going on? I can select and log any other items with no problems.  Thanks,
Wilson
Wilson,
PM me your email address and I'll send you my parameter config file. I have a feeling that you're using the same file I first attempted using because those failed parameters look very familiar. I clicked through the error and data logged with it anyway and Torrie said the logs were not usable. He then gave me a list of needed parameters and I built my own config based on his recommendations. He analyzed the resulting logs and found no issues.
That was my old config.  I think my sct has new firmware and I have not built new one.  Glad to hear you got help.  Pm me if you need anymore help.
No problem, Wilson! I'm glad you got it working.
NMB, I kind of figured it was a difference in firmware or hardware (I'm using the X4... not sure what you were using). Thanks for making the config available to everyone though. I suppose I should put mine out there too since it seems to be working for others.
