I am thinking of converting my interior and exterior lights to LED's. I have done my research and I think I may have the proper parts. But I am not good in the electrical department. I would appreciate help with confirming whether the parts I show are correct / will work, and any suggestions or advice you may have. I have read through all the how to's, that's where I got most of my info. I posted a link to each individual part, with a description under it.
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/5k-white-led/5k-white-4-led-2w-high-power-bulbs-194-168-158-1-pair.html
This is what I am leaning toward for the interior dome lights, or
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/5k-white-led/6-5k.html
But these may be too bright.
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/5k-white-led/5k-white-high-power-led-bulbs-194-168-158-1-pair.html
License plate and map/vanity light
http://www.vleds.com/shop-bulb-numbers/194-168-158-led/amber-led/6-a.html
Front side markers. Mine are really dim so they may need to be replaced regardless. Since the cover is amber, I am sticking with amber color.
http://www.vleds.com/shop-bulb-numbers/3157-3157ck-3156-led/switchback-led/5k-type-2-dual-color-changing-white-amber-switchback-42-high-power-led-turn-signal-bulbs-3157-4157-1-pair.html
Front turn signals
http://www.vleds.com/shop-bulb-numbers/7443-7443ck-7440-led/5k-white-led/5k-white-7443-21-led-parking-back-up-light-bulbs-7440-1-pair.html
Back up lights
http://www.vleds.com/shop-bulb-numbers/3157-3157ck-3156-led/red-led/3157-red.html
Brake lights
http://www.vleds.com/shop-bulb-numbers/921-led/red-led/red-14-led-5w-high-power-3rd-brake-light-bulb-921-1-each.html
These would be for the the very top bulb in the tail lights, the small ones. Not sure what you would call it; rear side marker, parking lights, other?
http://www.vleds.com/shop-bulb-numbers/7443-7443ck-7440-led/red-led/7443-21-red.html
Rear turn signals
http://www.vleds.com/resistors/turn-signal-resistors-6/turn-signal-resistors.html
Load resistors for turn signals.
I think I have everything covered, and with the exception of the front side markers, which I think may be a PITA to replace, it should be a fairly simple and straight forward job. I already have the mirror lights covered. And I can't for the life of me find anything for the lower "light strips" on the front. If an when I do this job, I will post a how to. I know there are some already out there, but I haven't seen any regarding the rear lights. Thanks
Front turn signals
Back up lights
Brake lights
Rear turn signals
