This should be the OE- CAC- Dimensions! ZAgentlongwood said:To me that sounds much more complicated than paypalling Matt $650 (Or less on group buy? hint, hint)
haha very true. But I do wonder how much the cost would be to do it on your own... Anyone know the dimensions of the factory intercooler? I want to find out how much a properly sized bar-and-plate core would cost.
Factory end tanks are plasticAgentlongwood said:Well if all those numbers prove accurate, and the price stays the same, I would most likely be buying one as well. Kind of mind blowing that the gains are so substantial just by switching to bar-and-plate, with the core going all the way to the end tanks. If that's the case, couldn't you buy a bar-and-plate core in the proper dimensions. Then get some end tanks from a junk yard and have them attached to the new core. Or is this way more complicated than I'm making it sound?
mattr66 said:Factory end tanks are plasticAgentlongwood said:Well if all those numbers prove accurate, and the price stays the same, I would most likely be buying one as well. Kind of mind blowing that the gains are so substantial just by switching to bar-and-plate, with the core going all the way to the end tanks. If that's the case, couldn't you buy a bar-and-plate core in the proper dimensions. Then get some end tanks from a junk yard and have them attached to the new core. Or is this way more complicated than I'm making it sound?V1 of the intercooler use an aftermarket intercooler and just replaced the core with a higher flowing one with more surface area... V2 has newly designed end tanks to flow more air and have a flange like stock for ease of installation.
We were all thinking itSHOdded said:Any updates as to when the intercooler will be released, Matt?
Macgyver said:So if you had a 93 tune. 12.5 1/4 mile time HP area. What gains and such would you expect from this IC?
Macgyver said:Macgyver said:So if you had a 93 tune. 12.5 1/4 mile time HP area. What gains and such would you expect from this IC?
I never said anything about IATs. I just asked a simple question. What will this add to the performance of a 12.5 second car.
