New Mustang for Bruce
I am mad, disappointed, embarrassed, PO'ed and disgusted with my Mustang.  I ran it today and it was a mess.  Violent wheelhop in 1st and 2nd gears.  So bad that it was just a matter of time until I broke something.  I had installed a kit that was supposed to stop or at least help that but it did no good.
The car is making good power and I know how to shift it but I cannot race it like this.  I still like Mustangs but I will be looking for one with an automatic.  They do not suffer from the wheelhop problem like the manual cars do.    This is a well known issue with manual Mustangs with the independent rear suspension.  It can be fixed with solid bushings in the rear suspension but the fix makes the car a very poor daily driver - adds terrible noise, vibration and harshness.
At least I cut a pretty good light.
Bummer Bruce. Sorry you weren't happy with it. The mph is pretty good so it seems like the car should run great if it would hook (well not hop). Agreed on your reaction time. Nice job!
Sent from my XT1650 using Tapatalk
My Mustang should be a mid to low 12 second car.  What is frustrating is that Ford equips these with line lock and launch control.  Trying to use them just causes the rear end to go into a spastic fit.  I can slip the clutch and feather the throttle to avoid wheel hop in 1st gear but the real problem is on the 1-2 shift where it is unbearable.
I am jealous of you SHO and MKS guys with AWD and automatic transmissions.  Next time I go to the track it will be with my Continental!
Drove my buddies 2015 PP at the track and cut high 1.8s on all seasons.  His was completely stock though.  Burnout had to be in second gear or it hopped badly, launch was at 3k feathered.  I took it easy on the 1-2.
This jackwagon cut a 1.1 60' ft... I ALMOST had the guy... seriously...LMAO...
When I lined up, this dragster pulls next to me in the left lane... I looked at the pit crew and asked "Are you serious?"
I had him off the line for .027 seconds...
great r/a bruce, man the pros rarely get there. the wheel hop manuals is not a pony problem alone. hear same thing on the manual chally scat packs. the a8 though is a totally different animal. line works no wheel hop @ 1500rpm, but if shifting manual got to be really on the ball or will hit the rev limiter in 1 or 2, the a8 smoke the manuals every time. well you got that hot-rod lincoln to fall back on. she has made a fool of a number of hot shots.
hawkeye93 said:
Will I see you at Brainerd on Wednesday, Bruce?  It would be fun to line up together, whichever car you want to bring.
Fun for you and your meth burner, I am sure.    I was going until I found out how bad the Mustang wheel hops.  I am done with it.  I am not running the Conti until I get a better tune for the transmission.  Doubt if I have it by Wednesday.
I am on a major Mustang forum and there is a list of the best quarter mile times for Mustangs.  Automatics dominate the list.
Is there an inexpensive way to stop the wheel hopping? Or at a minimum bring it within a manageable amount?
Basically replacing all rubber bushings in the rear suspension with hard bushings, replacing some links with upgraded pieces and running drag radials the fix.  Those who have done it report a lot of noise and harshness and don't recommend it for street driving.  Replacing some of the bushings require significant suspension disassembly and use of a press.
I did install a kit that clamps down on some of the rubber bushings making them stiffer and also installed some steel braces that are sort of like traction bars that are used on leaf springs.  I have about $500 invested in suspension parts but it doesn't seem that they helped much.    The cost of a complete fix doesn't bother me as much as making the noise, vibration and harshness too much for decent street use.
That's too bad.  I took the day off work to play some poker in the morning, followed by some racing in the evening.  It's almost like being a bachelor again.
Sent from my OnePlus 5 using Tapatalk
Yikes! Seems like Ford dropped the ball a bit on these MY mustangs...
I completely agree with you, don’t want to sacrifice street ability for track use...
Here are the top 15 stock Mustangs from the forum that I am in.  Only 2 with manual transmissions and both had the performance package and 3.73 gears.  PP cars do have stiffer rear suspensions so they must not hop as much.  The automatics do not suffer from wheel hop like the sticks do.
$500 in suspension on a mustang is basically nothing... My rear control arms and lowering springs alone cost that much or more. What setup exactly do you have? there are some known good brands, and some known bad, and some in the middle...
