Been lurking and searching foe a few hours and have the idea that the "life time fluid" is bunk. But I am 100% no longer capable of doing these things myself.
Being that the SHO's have been around for 6 odd years now would I expect any 'guff' if I ask the local Ford dealer to change the fluids out (front tranny and RDU)? Or should a *reputable* ford dealer acknowledged that the fluid should be cycled in the front AND back and just quote a price...
My sho has 40k miles. Is a 2010 NON-PP.
Here is the reason for the Question :: From the looks of it and the OEM year 2009 *original* tires and new battery I found I suspect it sat for some time after the 1st owner traded it in and it went to auction. If I had to guess from the tire rot it sat for at least a year. so ..
1) is the tranny fluid and RDU oil toxic at this point and I should go straight to "get that s%^t out" ?
2) will OEM fluids in the tranny and RDU hold up to long term standing and its 'fine for now' ?
3) is it possible for the 'quick change' places to get fluid samples out of the transmission and "RDU" or should I ask the dealer for a white sheet splat ?
4) Kind if a duh, but should I NOT drag strip it before changing the fluid and tuning it ?
The intended use of the car is daily driver + 3bar + colder plugs at .030 + tuner from Torrie with a 91-tune. *Maybe* downpipes at a later time.
Thoughts for the Noob ? Any and all are appreciated...
