Spoolin-SVT
I have 2010 SHO and I just hit 60,000 miles so I ordered a SCT Livewire TS tuner from torrie at unleashed tuning. the issues that im having is if I would load any of the tunes wether it be the 87 octane one that comes on it or if its the performance once that torrie has made.
Keep in mind this car is perfectly fine under the stock tune. But with any tune loaded it will studder from 3k rpm and up. Its worse under the performance one. If I keep in it under the performance one it will get worse up top cutting out wise and the check engine light will begin to flash for 1 to 2 mins then stop.
This car is 100% stock other then the tunter, I have a set of ngk6510 spark plugs , a 3 bar map and a 170 t stat on its way but wont be here till later this week.
While im waiting for the other parts to get here i decided to pull the spark plugs, i figured that they were the originals and they would be in pretty bad upon removal but to my surprise they were all in pretty good condition. They were all gapped betwwen .036 and .038 i regapped em all at .030 and reinstalled for the time being.
This alone actually made a pretty big difference while the car was on a performance tune and didnt really cut out like it did before. Pulls felt a lot smoother bu it still seems like it studdered sometimes through out pulls and bit more on the top end. And sometimes it seemed like there was some detonation on the top end.
Not wanting to risk hurting anything i decided to try and load the canned 87 octane tune that comes on the device from sct. ( I run premium, 92 octane). Tried that and it didnt seem to bad but i stil heard a bit of detonation on the top end and i feel a weird chatter between 1-2 gear under WOT.
Almost seems like the front wheels are hopping but the traction control light doesnt blink or anything.
Not sure why it would detonate at all under the 87 octane tune while im running strictly 92. Felt like i would be completely fine with that tune.
One thing that im not sure of is that im running the factory 2 bar map sensor which form what I read they like seeing boost above 14.xx and on all of the tunes including the 87 octane one, i was getting a max boost of around 15.27 psi.
To sum it up, my car is studdering under WOT and feeling a weird chatter between shifts and seems to be doing some detonation at WOT even though my factory plugs are gapped at .030.
Any help or ideas would be greatly appreciated.
