Oem Brake parts for '14 PP?
jbeez
Just ordered the following on Amazon... From reading through all the threads here and trying to cross reference part numbers, i *think* I ordered the right thing. But being 2018 and having access to the internet, its always great to post what you did so someone can tell you you're wrong LOL
Front Rotors: 2* BRRF318 ($76.82/ea)
Front Pads: 1set BRF1475 ($42.68)
Rear Rotors: 2* BRRF92 ($54.87/ea)
Rear Pads: 1set BRF1383 ($54.78)
The brake part situation for these cars is unnecessarily complicated, why are there so many options? There were options for painted calipers too? Which SHOs had painted calipers? Why would that even change the brake pad and rotor selection? ......
Are those older part numbers? I went looking cause I also Have a '14 with PP, and those PN's dont come up, (i was looking on Levittownfordparts.com), seems as thou ford has a new PN system.
Also for what its worth, you could also go with a PowerStop Z23 Kit from Scumit, https://www.summitracing.com/int/parts/pwr-k6375/overview/year/2014/make/ford/model/taurus, only an additional $90, plus free shipping. I run them here in Germany and they definitely saved my bacon on the autobahn more than once...
Painted calipers actually refers to the PP 20" daisy wheel setup, not actually calipers that are painted.  Just like brake rotor sizing on the Edge refers to 18" rotors when it actually means what came with 18" wheels.
Pads are different between PP and non-PP setups, as PP is more track-oriented than non-PP from the factory.  BUT whether the caliper differences (x-drilled piston, orange seals) from 2013 MY still apply, IDK.
I've been very happy with the stock setup and didn't want to introduce any new issues, I like how it is now so I didn't want to change that. I got 53,000 out of the factory pads and rotors and they do a great job stopping me :)
ZSHO said:
This is based on my Vin number!  Z
  13+PP-SHO
FRONT BRAKE PADS -DG1Z-2001-E replaced by DG1Z-2001-F
FRONT ROTORS -DG1Z-1125-C replaced by GG1Z-1125-A
REAR BRAKE PADS  -DG1Z-2200-B
REAR ROTORS  -DG1Z-2C026-A
https://www.fordpartsgiant.com/parts/ford-rotor-asy_dg1z-1125-c.html?Vin=1FAHP2KT5DG183206&Filter=()&Location=front-brake-discs-and-calipers,,1125
Looks like the front rotors are diff, the ones you posted are BRRF202 , pads seem to match the pads I ordered, they list the same part number in the description you listed.
It seems my rotors may be the police sedan versions. I'll just return them since i ordered from amazon, it should be easy.
After I get all the parts and install I'll update this with all the part numbers that I think are the OEM parts.... lol  new version and old versions of the PN if I can. Some of them reference both, others don't so I have no idea why the part numbers are all over the place.
I think the rotors I originally ordered would work, but I odnt think they are vented near the hat and ring so I want the original ones like you posted and just snagged those as well.
edit: moments after posting this, amazon showed up with my front pads.
box says BRF-1475  1X
DG1Z-2001-F
and inside is a set of instructions for 2013 SHO PP  on the paperwork, sticker says packed 17APR2018  and it contains two little tubes of orange grease as well.
BRSD1611A Was the number my friend that works at Ford gave me as per my VIN.  They came in a severe service duty box and have blue backings.
The mystery deepens!  Would help if people post pics of the parts and the boxes they came in.  May be an idea for a new thread altogether ... Hmmm.
When I have all my parts together I'm going to get pics of them to go together with the part numbers :D
Going to be putting the pictures of the brake parts in this google album
https://photos.app.goo.gl/L7exoi1kGEykocYf8
Got everything in, took some pics and updated that album.  I just don't have pics of the front rotors opened, the boxes are plastic strapped and I don't want to undo those until I get them to where I'll be installing, i'll try to snag a pic but pretty sure they are just with the vents in the hat base.
FYI - I had the brakes ordered & replaced by the Ford dealer under warranty a couple years back & AFAIK these are the correct brake pads applicable to the PP- SHO!  Dunno!  Z
2013+ PP-SHO Front brake pads.
Part #: BRF1475 (2001)  $72.69
https://parts.ford.com/shop/en/us/disc-pads-and-brake-shoes/kit-brake-lining-7867527-1
https://parts.ford.com/shop/en/us/brakes/disc-pads-and-brake-shoes
