DstryEvrytng
So. My SHO is pissing me off yet again.
Oil is leaking from the Turbo pipe with the blow off valves on it. Back behind the motor where it looks like there is a connection in the pipe.
Oil is on the valve cover also.
I can smell burnt oil outside of the car after i park it. Not terrible but not just slightly either.
Oil level is good so far.
Can i drive this thing untill it gets to the dealer or better off not?
Thx.
Edit = upon furthur inspection it looks like the oil is either coming from the cac tube where it connects to the rubber hose and spraying onto the driver side rear spark plug. Or its coming from the plug hole and spraying on the cac tube.
I dont really see how the later is possible but those arw the two spots with fresh oil.
The cac tube connection also has old dirt/oil mix on it.
Thx.
