Oil smell & smoke between engine and firewall
PopolZ
Did a bit of reading and beside maybe the valve cover and most likely the seals of the oil lines feeding the turbo, anything else can cause it?
Cracked turbo piping would be another possibility.  Has usually been up front, but starting to hear of cases in the rear also.
thanks guys. I'll roll that thing up the ramps and take a look at it next week.
just to be on the safe side I'll roll in a rental for my trip out of town this weekend.
Well as far as I can see it's coming from behind the heatshield between the turbo and firewall on the passenger side.
edit: doesn't have the smell of engine oil..
https://drive.google.com/open?id=0B7iGOSP9BPBlYTNMMldCQlpGbEE
https://drive.google.com/open?id=0B7iGOSP9BPBlOUNTamlGUHI1a0U
Is there oil above that heat-shield or does it start right there at that boot in your second picture?  That boot under the heatshield is your steering rack, looks like it might be dripping/splattering on the exh which would stink and smoke...
Got my car up on a lift today... this time the oil was fresh and smelled like engine oil and it is indeed the oil feed line leaking.
