dcmartinpc
Member
OK, so I will preface this with there has been a LOT of work performed on my SHO in the past couple weeks and I am not one to let other people work on my vehicles, but I didn't feel comfortable tackling the subframe. I purchased it knowing some of the problems, others were discovered as we got in to it. This is one of the, if not the best ford shop in the area. Now everything is in good shape except for 1 issue.
First I will give a background as to what has been replaced.
Subframe
Knuckle LF, RF, and LR
Struts and mounts LF and RF
Lower Control Arm LF, RF, and LR
Rack and Pinion
Wheel hub bearing LF, RF, LR
Toe link LR
CV shaft LF, RF
The drivers side CV shaft was a bit of a debacle. They replaced it, but apparently they received the wrong shaft and it was too long and I was told it was pushing the engine over about 2 inches, and they drove it with that axle in place! They pulled it and put the original shaft back in while waiting for the new shaft to come from Ford. Counting that up, the driver's side axle was swapped 3 times. This information is important for what comes next.
4 days ago I was taking off and the transmission slipped and it started making a whining noise while in gear that changes with engine speed, like a hydraulic pump running low on fluid. I checked the transmission fluid, which as many of you probably know means you have to remove the airbox. Found low fluid and topped off. I took it immediately to the shop. They said they couldn't centralize the leak but it looked like it was coming from the front cover. I told them I wish they would have called because I could have told them my 4 year old decided to "help" while I was topping off the fluid and a significant amount was spilled on the front cover.... Anyways, they degreased everything, topped off fluids and asked me to drive it some so the leak would show itself and come back Monday.
I drove it over the weekend as asked and decided to check everything out myself. Jacked it up in the garage and I could watch fluid dripping from where the drivers side cv shaft enters the transaxle. Now I am finding out they didn't replace this seal when replacing the axle, which would be fairly standard procedure for me while the axle is out and now it is leaking. Seems to me replacing the shaft multiple times left much opportunity to damage said seal, but now they are wanting me to pay for the seal and labor to pull everything apart and replace everything... Not happy as I feel this should be on them.
Beyond the seal, I am worried about the health of the transmission and the whine. I don't know if it is still whining as I am supposed to pick it up this afternoon. Should I be concerned?
Thoughts from other folks here? Am I out of line? I am OK with paying for the seal itself, but feel the labor should be covered under their 12 month warranty. Should I pursue a new transmission if the whine is still there?
Thanks!
Don
Subframe
Rack and Pinion
Toe link LR
CV shaft LF, RF
Thanks!
Don
