Car is still @ dealer and they called me to say that the diagnostics are inconclusive.
So I researched it the code and according to the
http://www.fordobdcode.com/p0020-ford web site
P0020 - "A" Camshaft Position Actuator Circuit (Bank 2)
OBD Trouble Code P0020 “A” Camshaft Position Actuator Circuit
What does the code mean? OBD-II Code P0020 definition:
A P0020 code definition:the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car’s PCM (powertrain control module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0020 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine). Bank 2 is the side of the engine that doesn’t contain cylinder #1. Note: This DTC is nearly identical to P0010
Symptoms of OBD code P0020
Check Engine Light illuminated (Malfunction Indicator Lamp) Rough running other symptoms may also be present
Causes of the OBD-II code P0020
A code P0020 may mean that one or more of the following has happened: Faulty oil control valve (OCV) Open or short in the VVT/VCT circuit Open or short in the OCV / solenoid valve Damaged computer (PCM)
Solutions Some recommended troubleshooting and repair steps are: Carefully inspect the Bank 2 VVT/VCT system circuit wiring and connectors, repair as required with a warm engine, test the operation of the OCV, replace/repair as needed
Related Codes P0010 P0011 P0012 P0021 P0022
