Last two days from a cold start, I'm getting code p0236 with the wrench on the dash.
https://www.obd-codes.com/p0236
This only happens from a cold start after not driving the car for 12+ hours. If i try to drive, there is a lot of hesitation and no power. I'm assuming the ecu is cutting off power to the turbos because of the fault.
If i turn the car off and back on, problem goes away. Car drives completely normal. Nothing ever happens and i never get any codes while driving. This is only from cold starts and the code goes on immediately which is why i'm thinking it has to be electric related.
MAP sensors are both clean, but i'm thinking one of them is possibly going out and needs to be replaced. Wires all look good and clean. Any ideas?
