JB9 CHECK THE SECONDARY COIL RESISTANCE FOR THE MISSING CYLINDERS
Ignition OFF.
Suspect coil connector disconnected.
Measure resistance between: Suspect coil connector, IGN START/RUN, component side and ignition coil spring, located in the ignition coil boot.
Is the resistance between 5,000 and 6,000 ohms?
No
INSTALL a new COP.
Clear the PCM DTCs. REPEAT the self-test.
Ignition OFF.
No
INSTALL a new COP.
