passenger door lock gave it up
68_GT
Has anyone had this problem ?
I can't lock the door..... even if the door lock pin is up or down the door doesn't lock and it doesn't move when I hit the lock / unlock button in the car or with the fob.
how long would the warranty cover that repair ?
There are actually a couple of TSB and one recall pertaining to the interior door handles,would personaly start off by getting the recall fixed if not done so already and while your there mention the issue your having cause it could be your lock latch assembly which is a pretty easy fix,or it could be the door sensor built into the outside handle which is bad,should be covered under warranty.BTW when putting your hand inside the door handle do you hear the actuator moving like the drivers side? Z
I had same exact issue on the driver door.
Dealer replaced the lock latch assembly.  Required taking inside door panel off, fairly quick fix if they can get part.
Now I'm paranoid that my doors aren't locking.
mine started working again so I guess I'm good for now but paranoid the door is unlocked all the time now....
