I know this is an old thread, but it came up during my research on what exactly comes on the Performance Package.
The PTU cooler came up and bpd1151 pointed out that it is integrated on the PTU and not easily retrofitted. So I looked up the PTU part numbers on Tascar Ford, and there are basically 2 PTUs for 2013-up SHOs:
AT4Z-7251-E (to 7/16/13)
DG1Z-7251-D (from 7/16/13)
Doing a Google search for those part numbers, I found a Russian website with 3 pictures of the DG1Z-7251-D PTU:
https://www.avito.ru/moskva/zapchasti_i_aksessuary/dg1z7251d_korobka_razdatochnaya_eksplorer_709931422
If you look closely, you can see the cooler sticking out. I had to make sure by checking this photo to see where the cooler was located.
I'm recovering from surgery, otherwise I would have crawled around my car to see if it came with one. I checked today for the trans cooler and engine oil cooler (easy enough to do from the outside) and it didn't come with them. I had to check, because you never know if Ford started slapping these on all the later cars. They did it with the aux trans coolers on the Crown Vics after 1998 or so.
Some background info:
I factory ordered my 2014 SHO with only Navigation and not the Perf Package because it was a lease, and I was picking it up early January in Michigan where the summer racing tires would be useless. The day the car arrived, there was about 6" of ice and snow on the roads. My lease is coming up in less than a year and I'm trying to figure out what to do. I also found out that while HPTuners does support the SHO for tuning, the pre-15 Fords with the Tri-Core 1797 processors have a lot of the tables missing (shift maps for the drive modes and throttle settings for the drive modes), so everything is pointing against me buying out the 2014. There's no word on a 2017 SHO, but I saw an article where Ford was thinking of producing an updated SHO, but the fact remains Ford has been tight lipped on the 2017 and future Taurus for the US for the last 2 Detroit Auto Shows - but has been providing bits and pieces on every other 2017 model.
