TopherSho said:Nope never did. Read to many horror stories.
AJP turbo said:TopherSho said:Nope never did. Read to many horror stories.
Well I'd say most of the horror stories are from people that try to update without reverting to stock like the instructions say to do....I'm not going to say this will fix anything but I update my software almost daily so there is a chance that if I made a tune and you were on some old firmware or software that might not be good.
I would update your device weekly if prompted to do so especially if you are currently in tuning sessions with someone.
So when you load a tune onto your device in the updater program and it has been prompting you to update and you ignored it?
And also the auto update box does everything in one shot...Firmware, software...The firmware update is for tech support only, it says that.
TopherSho said:ok here is two STOCK .96 OAR level logs.
LOG1 :: One is the wealth of new pids i found .. including wastegate pids for the bypass and baraomoter.
i included a bunch fun troubleshooty sounding stuff. i have no idea if anyone else has anything they can help compare me to... if you have a 2010 with DMJKBLA id be curious if you logged the same pids on a 1-4th gear autopull what the diffs might be.
LOG2 :: std brad logging cfg file datalog.
now here's the fun new part. it is no longer doing the bad behavior in stock mode. in fact stock mode is way stronger than i recall it being.. wierd but ok. gives me about an inch of hope.
swapping back to my good solid tune from before the meth, off to drive the oar to .96 and get the same 2 logs.
FoMo; yeah Brad an i log the spark, knock, tqsrc. with the new pids i found i added anything that said 'safe', 'fault' or error and the usual tqsrc and knock and misfire to the new 'wth' config file.
when i get my 'tuned' OAR back to .96 i will run the same two logs i just attached with it, it is a 14psi tune with a emphasis on spark from brad.
all comments are appreciated.
this have been going on for almost 6 months so if it sounds like panic it is a mix of frustration, desperation panic and a dash of pissed offthe fact Ford has not idea whats going on is super frustrating.
I am very tempted to start tuning from scratch and get a base tune from brad and go through the basics again, see where we hit the wall. Brad what do you think?
How many PIDS does your strategy have?ZSHO said:I appreciate the responses from ^^^ as this Topic alone has helped me setup my newly acquired X4 in organizing a list of standard Pid's and hopefully will do some logging in the coming weeks to see what the crap is going on! LOL. Thanks! Z :
There is probably more than one 'knock' reading but i will re-scan the pids and look back in there and see if i added the wrong one.AJP turbo said:Looking good so far and much better but on the log that said "test other" your knock sensor reading went nuts and something is wrong with the reading...It went to like -20 and I know you weren't adding 20 degrees of spark and your spark was normal looking in the high teens.....I thought you had another log like that today....but the resolution looks so much better now
It is toggled off. no juice in the circuit, the pump is direct to battery. the relay is ignition hot wire powered, and its wired off the ignition to a single pole toggle so i can de-power the circuit at my command. it has been of since late september/early october?AJP turbo said:You say you have the meth shut off now.Is that like powered off? I've been wondering if you have something electrically backfeeding into something?
stealbluesho said:Dude... those logs look really good... I can't see anything in them that shows a hiccup. NOW... I will say this... being as we both have the same strategy... sometimes with the SCT platform tunes I experience what feels like a miss.. its like a quick hiccup in the higher RPMs every once in a blue moon... happens with BCB, Unleashed, and Brad. I have spoken to Brad about it before but to date I have not been able to find a single shred of evidence in the logs to show it.
It feels like it falls on it face for a split second before going again.. its really short.. like I said.. feels like a misfire. NONE of the LMS tunes produce the same oddity buts its a different platform.
stealbluesho said:There was another user on this forum that had issues with stuttering as well but only with SCT tunes.
My stutter usually only happens one time really quick, I have had it happen once or twice where it’s a few of them back to back like you describe. Like I said, it’s not isolated to Brads tune but it only happens with SCT tunes.
Good luck in you testing... I will be following this one closely... if you can find a PID that captures what is going on that would be AWESOME. I have logged at some point every PID/DMR available looking for something...
FoMoCoSHO said:Not spark, spark source, its like torque source but for spark.
