I had a Code (PO316) the other day that suggested Misfire Detected On Startup (First 1000 Revolutions)
Description
DTC P0316 sets in addition to any type B misfire DTC which occurs in the first 1,000 revolution test interval following engine start.
Possible Causes
Damaged crankshaft position (CKP) sensor
Damaged ignition system
Damaged fuel injectors
Running out of fuel
Fuel quality
Base engine
Damaged PCM
Diagnostic Aids
Freeze frame data and the DTC P03xx are also stored, indicating which cylinder the misfire occurred.
Action
GO to Pinpoint Test HD.
Mode 6 is self monitoring that the car’s computer does to detect misfires. After the number of misfires exceed a pre-determined threshold the check engine light will be turned on. Mode 06 access looks at the misfires in a cylinder before the light comes on.
I had Ford IDS Power Balance Test and Mode 6 Data on the car performed today and found absolutely (NO Misfires) of any kind and all is Good. Z
FYI for anyone interested its surely a great way to troubleshoot any underlying issues related to misfires and i'm sure your local friendly Ford Dealer can have this performed with an applicable Diagnostic fee.
(Data results below). for your viewing pleasure. Z
http://www.youtube.com/watch?v=jOFL99D_f4Q#
Description
Possible Causes
Running out of fuel
Fuel quality
Base engine
Damaged PCM
Diagnostic Aids
Action
