sholxgt said:I've had good success with EBC slotted rotors on other cars. I need to give them a try since I'm about done trying things with my Lincoln.
I'm running PP calipers and police spec rotors and pads now. They still suck! A handful of turns with the stability control working it's butt off and my brakes just fade away. Running ATE brake fluid and being as gentle as I can, but the mountains just turn my brakes into mush.
I wouldn't even notice that the brakes are inadequate if I still lived in FL, but the mountains are like a race track except it's every day/all day. Had about 10 vehicles since living here and this one has the most ability to outperform it's braking ability.
sholxgt said:I had and loved Carbotech pads on another car, but I think my problem is heat. My brakes work great until they don't.
Thinking about EBC slotted rotors maybe? They make more noise, but thinking they may offer some help in the heat/pad glazing area.
Wilwood makes some great stuff, but I wouldn't spend that kind of money on this car. There's just too many things about this car that isn't quite right. Mine is the typical Ford with 90% done right and 10% done way wrong. Don't get me wrong, I like the car. I just don't see my owning it past warranty.
sholxgt said:There's just too many things about this car that isn't quite right. Mine is the typical Ford with 90% done right and 10% done way wrong. Don't get me wrong, I like the car. I just don't see my owning it past warranty.
Agentlongwood said:sholxgt said:There's just too many things about this car that isn't quite right. Mine is the typical Ford with 90% done right and 10% done way wrong. Don't get me wrong, I like the car. I just don't see my owning it past warranty.
My biggest complaint is the seating position. The pedals are WAAAYYY too close, even when adjusted back as far as they go. If I move the seat to where my legs are comfy, then I can't reach the touch screen without leaning forward. If I move the seat up to where I hold the wheel properly, then my knees are hitting the steering column. If the pedals had about 3-4 more inches of travel it would be perfect.
Other nit picks. I can't see fuel economy and tachometer at the same time... Who does that? Some body panels don't line up perfectly. It's not crazy bad, but enough to notice. OFFSET BABY SEAT HOOKS. Why Ford, Why... Why does the baby seat, sit about 1/3 of the way into the middle rear seat, lol.
Other than that, I really love the car. It's big, it's comfy, it's got TONS of great features, and it's easy to make it fast. So I think you're about 100% correct. The car is 90% great and 10% "wtf were you thinking, Ford?"
SilvererSHO said:I'm also not one bit impressed with my top of the line stereo system offered by Ford either. Sound quality is not very good at all. I wish you could tap the cruise control buttons to speed up or slow down in 1 MPH increments. I miss that feature that was also on my wifes Traverse.
Agentlongwood said:SilvererSHO said:I'm also not one bit impressed with my top of the line stereo system offered by Ford either. Sound quality is not very good at all. I wish you could tap the cruise control buttons to speed up or slow down in 1 MPH increments. I miss that feature that was also on my wifes Traverse.
I actually really like the 2013+ interior on the MKS. Although I do like the 2010-2012 Taurus shift level. It's like a big ole' T-handle. The 2013+ MKS also has a better sound system. If you get radar cruise, you do get the ability to push a button to raise/lower speed in 1mph increments. Join us on the dark side, go MKS. Once you get over the grandpa-car styling, they are great lol.
derfdog15 said:Is the Cruise Control different on the 10-12? On my 15 SHO IIRC, I just had to use the 'Set' button on the steering wheel to adjust cruise up/down.
SilvererSHO said:derfdog15 said:Is the Cruise Control different on the 10-12? On my 15 SHO IIRC, I just had to use the 'Set' button on the steering wheel to adjust cruise up/down.
Yes, but you hold it down until you reach the desired speed to increase or decrease speed don't you? I'm talking about 3 taps on one button to slow down 3 MPH. 7 taps on the other to increase by 7 MPH etc. etc. That's how the wife's old Traverse worked and I really liked it.
Agentlongwood said:SilvererSHO said:derfdog15 said:Is the Cruise Control different on the 10-12? On my 15 SHO IIRC, I just had to use the 'Set' button on the steering wheel to adjust cruise up/down.
On mine I can tap the button and it goes up by 1 mph. If I tap it 3 times it goes up by 3 mph. Mine has the adaptive cruise control. Not sure if the regular cruise control works the same.
Macgyver said:2015 SHO. Yeah the Adaptive cruise you can do +/-1 increments.
The thing that drives me nuts is the touch screen. So not a touch screen. More like a LAG or No touch screen and now the cold weather is messing up stuff with the No Key found and Battery saving mod etc etc. Another thread here.
On the OP post here. I would do Wildwoods if you are going to track the car. Dont skimp on tires or brakes.
Well I'll be damned.... I guess my '12 SHO does do it in 1 MPH increments. I tried the wife's when she first got the car and it didn't work and then tried mine and assumed it didn't do it because it's not nearly as responsive as it was on the wife's old Traverse so I didn't even realize it works. DUH.... I'm assuming since you can't get adaptive cruise control with the PP they give you the +/- increment deal without it? And then on my wife's car you'd have to upgrade to adaptive cruise control to get it?
