PP shocks in non-PP
It appears to be the same part number for the 13+ PP vs NON PP SHO,Minus the painted,non-painted caliper option.  Z
Rear Shocks
Front Strut
Thanks Z. You are very helpful as always. I'll just get the cheaper w/o painted calipers version as they are $20 less. The fronts didn't have a price difference so I'll stick with what was already shipped (w/ painted calipers).
SHOdded said:
The painted calipers option means the SHO has the perf pkg.
Then according to RockAuto Z would have a non PP lol.
MOTORCRAFT ASH23482 {#DG1Z18125F} Info
Rear; w/o Painted Calipers
MOTORCRAFT ASH23479 {#DG1Z18125C} Info
Rear; w/ Painted Calipers
Sadly more info is likely to be gleaned from articles in Motor Trend than from parts counter people.
Adam this is what you ordered correct ? I truly feel bad but it appears that the parts you ordered are the exact fitment for your vehicle a NON-PP and hope i'm wrong.  Z
MOTORCRAFT AST12328 {#AST12251, DG1Z18124F, DG1Z18124X} (Original Ride Quality) Info
Front Right; w/ Painted Calipers
MOTORCRAFT AST12329 {#AST12250, DG1Z18124E, DG1Z18124Y} (Original Ride Quality) Info
I believe the below part numbers are for the PP-SHO
FRONT STRUTS
18124
(AST-12321)
Shock Absorber
With Non Painted Brake Calipers, Brake Calipers - Black; LH (Front)
  $89.08
18124
(AST-12323)
Shock Absorber
Brake Calipers - Black, With Non Painted Brake Calipers; RH (Front)
  $89.08
REAR SHOCKS
18125
(ASH-23482)
Shock Absorber
Brake Calipers - Black, With Non Painted Brake Calipers (Rear)
  $110.38
I'll just return the 2 that got shipped out. Darn RockAuto was quick lol. I'll order the ones with "Black" which I guess are the PP ones. Thanks again Z!
I will try to get some (pics) and confirm the actual (PART Number) Needed pending if its in stock/shelf item in parts dept by Friday and is at least i can do. Z
ZSHO said:
I will try to get some (pics) and confirm the actual (PART Number) Needed pending if its in stock/shelf item by Friday and is at least i can do. Z
Ok man I'll hold off on reordering then.
Here it goes and can confirm fitment for the 13+SHO with Performance Package.  Z
FRONT STRUTS
MOTORCRAFT AST12321 {#AST12256, DG1Z18124U} Info
Front Left; w/ Black Calipers; w/o Painted Calipers
MOTORCRAFT AST12323 {#AST12257, DG1Z18124W} Info
Front Right; w/ Black Calipers; w/o Painted Calipers
REAR SHOCKS X2 Same part number
- MOTORCRAFT ASH23482 {#DG1Z18125F} Info
Rear; w/o Painted Calipers (X2).
Grand Total $269.73 in (cart) with shipping and 5% Discount code applied.  Z
http://www.rockauto.com/en/cart/
[BTW added two Stabilizer Bar Links in cart if you want them].:)
MOTORCRAFT MEF353 {#GG1Z5K483A, MEF162}
Front Left
$8.73
MOTORCRAFT MEF352 {#GG1Z5K484A, MEF161}
Front Right
$8.91
polskifacet said:
Just ordered the full list thank you ZSHO :bow:
Its always my pleasure to help out in any way I can and hopefully the install goes smooth without a hitch. Z
Adam best of luck.
Everything fits perfectly! Question I did have for Z is are the rear endlinks also redesigned? I ask because the rears have that same plastic and the pictures on tasca show it as metal with a debris guard.
Same part number for non-pp and pp so I grabbed them from the dealer already!!!
Also wanted to note IMO the fronts are easier that the rears. I had to do alot of heaving and heavy breathing to get the rear springs in the seat, and spinning them after i got the into the seat so the bottom hits the bump stop/ is aligned properly. From the How-to some guy said you need to pop the axel out on the fronts which is untrue. I do recommend a pass through wrench set as I had to improvise alot to get some of the nuts off.
