jimmyducati
I already went over the write up over at the edge forum and it didn't really get at my questions:
To Drill/Tap the PTO ON A 2010 SHO, do you have to remove the PTU from the car or can this all be done on a lift with the PTO still installed? I suction and refill my PTO every 10,000 miles or so and have an idea to make this easier than changing the engine oil!
By drilling/tapping the drain, then installing a plug in the factory fill hole that has a stainless steel line tapped into it (similar to the bleed line on a hydraulic clutch throw out bearing), you can simply drain the gear oil, then pump fresh back in and even flush it with the same line! The only way this works is if you have the drain plug installed though..
