So new guy here, tried a search and did not see anything about this so throwing it out there. Some of you guys here are really into these cars and the industry and maybe my idea will spark something? :icon_idea:
Has anyone researched some sort of filter system for the PTU? The PTU cooler I believe is running engine coolant thru the PTU not actually circulating PTU fluid thru the cooler? So that system will not be of use based on what I have read.
But with the 13+ and PP cars could something be done? Those have a drain and a fill port in the cases to use for in/out. Would there be enough movement in the fluid during normal operation of the unit to have it circulate out the drain and back in the fill port? If that is not possible, maybe a few fittings and a secondary pump and filter setup? It would not need to be any real sort of flow, even 1gpm would be a night and day improvement I would think? I could see the temp sensor possibly be a concern..?
Thoughts?
Thoughts?
