T TopherSho New member Jul 24, 2019 #1 QQ: Are Bosch injectors the factory injectors for the SHO? Ty in advance ..
Z ZSHO New member Jul 24, 2019 #2 I think the OE are indeed Bosch injectors IIRC! DW also makes an aftermarket alternative. Z https://www.rallysportdirect.com/fits/2013-ford-taurus-sho-3-5/fuel-injectors/det-19s-00-1700-6-deatschwerks-1700cc-injectors
T TopherSho New member Jul 24, 2019 #3 Thanks Z, you are always helpful with part numbers. I want to make sure they installed Bosch's on the rebuild. my wet cylinder \ misfire could be a *another* off injector if it is a OEM replacement that is not quite spec.
