Rear accessory power wire (2015 Non Sony SHO)
shohard
Hello everyone I have a question on my amp and LC7i install. I rewired all my speakers and added Rockfordfosgate punch door speakers rear front and tweeters. I taped into the wires in the back of the stock system.  I first cut the speaker wires and the wires coming from the speakers I ran them to the AMP output side and the wires coming from the deck to the LC7i input and RCA's outputs run to the AMP input. I did it this way so I can still control the speakers from the Deck. Now I need to tap in to an accessory wire in the trunk because I already button up everything like an idiot!
w
So does anyone know where an accessory wire is in the trunk or near the trunk that I can tap into? I just don't want to open the deck up again!
Thank You!
V/R
SHOHARD
glock-coma said:
What are you running the acc wire to? The lc7i has signal sensing from the voltage of the speakers.
I got my SHO about 6 months ago it is my first one and first American car. I am in love with this car it has everything that I ever wanted. I am in the Air Force and stationed at Nellis AFB. Love fast cars and building them I was mainly with tuners and now Ford has me turned on with the SHO. I look forward to meeting more SHO owners so I can get to know this beast a little more.
SHOHARD
I don't know yet. That is why I was asking for and ACC wire to go to. I would like a wire in the trunk but it doesn't seem to work that way.
might be easier to run an Add-a-link from an unused and ignition switched opening in the fuse box to the on-off switch.
I guess I should have asked what are you trying to power?  Are you looking for something to turn on/off with the radio? Or just when the car is on/off
I don't know where to run the remote wire to, every where I have ran it to seems to keep the AMP on even when I shut the car off. Any help there? Where do I run the remote wire to on a NON SONY edition SHO? All I can find is the Sony edition remote wire. So if the LC7i has a single from the speakers do I need a remote or will it power on when the car comes on?
I ran the Add-a-link to several spots but the amps stay on when the car is off. I ran it to where the sub fuses are and the accessory run fuse spot. What number fuse should I run the add link to and is it under the hood or under the dash?
I looking to be able to shoot the amp off when I turn the car off. What number fuse should I link to?
Doesn't the lc7i have a remote out? If your connecting the speaker wires from your radio into the lc7i you can use the gto (great turn on) feature on the lc7i.
It's a jumper you need to turn on under the lc7i cover and will give you 12vdc on your remote out.
Your Awesome!!! I will do that now. Hell yeah super excited!!!
