Rear window sun visor question
Cro
I have a sho equipped with one of these sun visors in the rear and I was wondering if anyone has found a way for it to stay up at all times regardless if the car is in reverse.
Is there a fuse for it, or is there a way that I can unplug the motor, so the visor stays up at all times even when the car is reversing?
Look for a small plug by the rear window and try to disconnect it with the visor up or you can remove fuse #8 ,which is 20amp in the engine compartment ,but it will disable your sunroof and rear sunshade.
Yes, the rear sunshade is what I meant. That's exactly what I want, to disable the rear sunshade in the up position so I don't have to get it up after every time I back up. Lol, the second sentance reads weird, but no harm intended. I don't want to disable the sunroof, so I guess the fuse is not an option. I will check the plug going to the motor, but it would really be nice if ford left us this as an option.
And thanks for the info guys, and the l link. I can't view the pic from that link, but I will attempt this in the near future to see if it works without giving any warning lights on the dash.
