802SHO said:Auto octane GH tune for bigger turbos same power as E30 GH tune with stock turbos or bigger turbos?
He said GH E30 with stock turbos.
SM105K said:SBS, why don't you just put in a stock T-stat and be done with it?
StealBlueSHO said:SM105K said:SBS, why don't you just put in a stock T-stat and be done with it?
Matt said there is benefit to the 170F Tstat.. 160Tstat is too cold according to him (and everyone else but LMS)... if I am gonna open the Tstat housing and make a mess again.. should probably do it with the one my tuner likes.
SM105K said:StealBlueSHO said:SM105K said:SBS, why don't you just put in a stock T-stat and be done with it?
What is the exact benefit? Once the car gets up to operating temp....what happens?
StealBlueSHO said:SM105K said:StealBlueSHO said:SM105K said:SBS, why don't you just put in a stock T-stat and be done with it?
So from what I understand... and I could be off on this... but the lower engine temps allow for more spark... IE.. if the car runs hotter, it tolerance for knock goes down based on the fuel supplied. Again.. I could be off, but Matt said there is a bit of power to be gained from running slightly cooler than stock.. I defer to his knowledge on this one. I have two stock thermostats sitting on a shelf, so I Matt says they are good to go, then I will use one of them.. otherwise, I will grab another 170F Tstat.
Jordan said:StealBlueSHO said:SM105K said:StealBlueSHO said:SM105K said:SBS, why don't you just put in a stock T-stat and be done with it?
Heat can equal preignition. Manufacturers want the happy medium for regular consumers not the performance oriented ones. In Michael's case I'd just say the stock one would just be a bandaid until he gets another one. Considering the amount of pressure and heat he is creating it's probably even more necessary than just a regular tune and bolt on Taurus.
SM105K said:802SHO said:Auto octane GH tune for bigger turbos same power as E30 GH tune with stock turbos or bigger turbos?
802SHO said:SM105K said:802SHO said:Auto octane GH tune for bigger turbos same power as E30 GH tune with stock turbos or bigger turbos?
I know I guess I was hoping it was a typeo. If I was already e30 tuned with stock turbos....then upgraded my turbos.I would be mad if after spending all that money I was back to the same power level as an e30 stock turbo tune with the auto octane upgraded turbo tune.
802SHO said:I gotcha, it makes more sense to me now and thank you for elaborating. I could be wrong but 93+meth seems similar to power of e30. I think at the end of the day we may have similar power even though I don't have the HPFP.
StealBlueSHO said:802SHO said:I gotcha, it makes more sense to me now and thank you for elaborating. I could be wrong but 93+meth seems similar to power of e30. I think at the end of the day we may have similar power even though I don't have the HPFP.
Potentially. I would invest in a HPFP... i mean.. you already picked up the rest of the portfolio.. then you can just use the meth for cooling and octane.. not a fuel supplement which can cause issues if the pump fails.
SHOdded said:Why do you suspect compression loss?
