Shifting points on a '14 Sho
cror1
I have a question for those that took their shos to the drag strip. I am wondering how far do you let the rpms raise before you shift to the next gear, from 1st-2nd/2nd-3rd/3rd-4th, and if you hit the 5th gear in a 1/4 mile? I just recently started getting familiar with this car, and I do not want to hit the limiter. I'm sure most of you know the feeling of having the nose down(of the car) at the redline. Not pretty, therefore, where do these cars shine in the rpm level to get the most out of them? And, I should probably add, I am completely stock. But do comment if you are tuned, just please state so.
SHOnUup said:
Let the computer do the shifting. Can't beat it.
Rich
seriously, it'll go all the way to the redline and shift on its own? I assume it has to be in S position? So what is the purpose of the paddle shifter then? Sorry this is my first automatic, I have too many questions.
Thought the same too after reading on how the car does it better than we can. I use paddles only when racing from a roll so I'm in a good gear instead of getting the hesitation.
Rich
So what's  the trick, keeping the gas paddle to the floor and never let off? tell me more, the whole story, lol, from start to finish...
Brake boost at 2200 rpm's and then take the skinny happy pedal and try to push it through the floor...lol
Rich
Thank you fellas. and lastly, it should be in D, not S? I should probably read the manual as I thought first that S stood for sport and manual shifting, but now it sounds more like slower driving??
It really depends if your car is tuned or not and what type of tune you have,some tunes really benefit the car in sport mode,for stock would keep it in D.
I may have to get this tuner for myself then, I read some good things about it. Well, I'll get to know this car as it's going to be my winter car.
do we benefit from running 93 in this car? I'll have to look into that ethanol mixture as well. what psi do you run in the tires?
IF your seeking full potential from your vehicle tuned or not and have 93 in your area then thats the way to go,tire psi 32-f-34-r,track 22-f-24r,hope this helps and good luck.
That's some low pressure. I went 28 front and 29 rear tonight at the track. I should have went a liitle lower because I was spinning a bit with a nice chirp into 2nd. It seemed like a grippy spin if that makes sense. Only made 4 passes and was content for the night, so no adjustments made.
Rich
Rich
Shonuup what brand plugs are you running?
There is a 93 in my area, next time I fill up it'll be 93. I think I had my questions answered, but I keep thinking I am forgetting something though.
Sp534 Motorcraft .030 gap
93 is a must for these cars IMO. Any less you run a risk of pre-detonation. I just started adding 2 gallons of e/85 to counter the winter blend fuel also. Great results so far. From 87 to 93 octane is like 10 hp stock.
Rich
So 2 gallons of e85 with 17 gallons of 93 octane, correct? What percentage mixture does that give you? I don't know much about e85, would that be considered as what they call it from factory, e10 or e15?
