If not monitoring your fuel rail pressure and AFR I would not exceed 2 gallons a tank, maybe 3. But a scantool combined with something to monitor on would be highly recommended in this area as all cars run slightly different.cror1 said:You guys are awesome, thanks for the help! I will do some research on e85, and start adding it to the tank.
How much and in what way do you feel Torque is off on the boost? Just curious.SHOnUup said:Turbos are rated for 14.7 psi. Torque is off on this gauge slightly.
Rich
With Dave's dyno pulls he was saying mid 13's for boost and running basically the same tune. Getting spikes in the 16 range leeds me to believe torque is a bit off. A good measuring tool though to compare to your own readings to detect a possible boost leak.Larrylu said:How much and in what way do you feel Torque is off on the boost? Just curious.SHOnUup said:Turbos are rated for 14.7 psi. Torque is off on this gauge slightly.
Rich
Maybe the dyno gauge was averaging or filtering to eliminate the not very important spike. With Torque we are left with a pointer spotlighting a spike.SHOnUup said:With Dave's dyno pulls he was saying mid 13's for boost and running basically the same tune. Getting spikes in the 16 range leeds me to believe torque is a bit off. A good measuring tool though to compare to your own readings to detect a possible boost leak.Larrylu said:How much and in what way do you feel Torque is off on the boost? Just curious.SHOnUup said:Turbos are rated for 14.7 psi. Torque is off on this gauge slightly.
Rich
Rich
