https://www.ecoboostperformanceforum.com/index.php/topic,6822.msg105306.html#msg105306
https://www.ecoboostperformanceforum.com/index.php/topic,7401.msg112711.html#msg112711
I suspected this is what it might be when I responded on SHOforum, but the coolant flow diagram sure doesn't look its the case ... IDK
"-The Interceptor Utility motor I got had an extra heater hose port that protrudes from the front of the motor under the throttle body below where the upper radiator hose attaches. I don't know what it's for, but I'm guessing maybe a PTU cooler or something of that nature due to the HD designation of the interceptor application. In order to delete it completely, it looked like I would have to remove one of the heads to get the coolant tube out, so I just plugged it instead."
