S SHOwoosh New member Jun 1, 2017 #1 http://www.dragtimes.com/Ford-Taurus-Timeslip-29226.html The mph is damn impressive. If there's another thread about this delete it.
StealBlueSHO Administrator Staff member Jun 1, 2017 #2 Meth and VP-109... that thing was seriously maxed out lol...
M Macgyver New member Jun 23, 2017 #3 22PSI. What is the usual boost for a Tuned 3.5 twin with no major bolt ons ?
S SHOdded Moderator Staff member Jun 23, 2017 #5 Spikes can be higher though, past the efficiency zone even, but generally not more than 20-22 psi for transverse applications.
StealBlueSHO Administrator Staff member Jun 23, 2017 #7 Not sure the stock turbos can run 22psi holding...
StealBlueSHO Administrator Staff member Jun 23, 2017 #8 That would mean he was targeting 253 kpa.... that would be insane.. the turbos hit that (mine has before all the time with Torries tunes) but it would be a boost spike... The 3BAR map can only see up to 255kpa...
StealBlueSHO Administrator Staff member Jun 23, 2017 #10 Unleashed tune... doesn't surprise me with the 60ft....Torrie doesn't hit with a lot of low end boost.... helps with being able to launch...
S SHOdded Moderator Staff member Jun 24, 2017 #11 3bar MAPs are able to see upto 29.4 psi, is this not true in practice?
StealBlueSHO Administrator Staff member Jun 24, 2017 #12 My 3BAR can see up to 255kpa which is roughly 22.7 psi... And the logs I have seen the highest recorded is 255kpa on the MAP... now the TIP sensor can see higher...
