http://www.summitracing.com/parts/mpe-11378?seid=srese1&gclid=CO_E0svl8b0CFUVgMgodiy4Agg
Buy that and use it to delete the cat and resonator, it is a straight through resonated x-pipe. You'll have less rasp and basically the same performance due to the straight-through design.
As far as axle back, you could instead purchase 2 high quality mufflers such as Magnaflow to match the resonated x-pipe or Borla, then have a shop swap those in or create a axle back out of them for you. At the same time you can throw on any exhaust tips to make it your own.
$300 in mufflers + $2-400 for labor depending on your area = $5-700 exhaust with no rasp and free flowing. You would be surprised how restrictive our original mufflers are, as free flowing mufflers are more prone to rasp the resonated x-pipe created with the Magnaflow should help in this department.
