Splash blending e85 to 93
18SHO
Anyone add a gallon or two e85 to 93 octane to lessen or eliminate any knock ? Especially running a strong 93 octane tune it could only be beneficial id imagine . Winter blend gas im sure is less potent as well.
Yes, LOTs of guys do it. A gallon to two TOPs, however, you may have fuel pressure issues depending on the tune.
Best bet would be to ask your tuner, based on your logs, if a couple gallons are safe.
Yep^ ask your tuner. They know best on what your tune is doing.
Not pointing any fingers, wish it was that easy guys . Reason why I'm resorting to the forum for some answers. Anyone who can look at my logs and help would be appreciated.
How much knock are you seeing?  What does your OAR settle to?  Tried different stations/brands?  Many resort to a lower octane tune with higher octane fillups for the winter.  Staying away from MORE ethanol during this time is recommended.
Below -1.00 often a couple different stations. Ethanol less then 20% won't hurt anything in winter. They say not too much ethanol in winter for startup issue . Drove my s550 mustang with flex fuel tune 40 % it was good anything higher it was hard at starting sometimes
If you want to PM me I will be happy to look at the logs, you getting them from an SCT device?
Yes sir SCT X4 , I'll PM you tommorow thanks
Should be able to attach the logs to your posts also to get multiple sets of eyes on it, if you want.  Or you can get a google drive/dropbox account, upload there and plant a link here :)
I would definitely check your data logs and ask your tuner first but typically we see on a car with a 93 tune and some bolt ons that fuel pressure starts to drop around 70 degrees and the colder it gets the more the fuel system will struggle, if you had an accommodating mod like a HPFP then a couple gallons mixed would be no problem, as you could do an E30 tune on this setup
If you're not too certain on the proper mixture,ratio just add a bottle of Heet preferably the (yellow bottle) @ every fill up especially during the cold winter months.  Z
18SHO was kind enough to send me a couple logs, he is good to go. His logs actually show near perfect fuel pressure 2000+psi.. and almost no knock.. less than +1KR (.8 iirc) at worst.
I think it was a polish notation issue.. SCT reports adding spark with negative knock values and pulling spark with positive KR values..
18SHO tune looks very well done for the fuel he is running.
Near perfect? LOL I love this log. The 3rd gear pull shows perfectly flat fuel pressure and this is a sustained commanded boost of 14 psi from 2700rpm to redline. Boost is green, nice and flat through the entire rev range.
And in the multi gear pull fuel pressure is basically unaffected even with boost spikes of 16.77 psi....And some of the very small dipping that you see is not due to too much boost or the fuel system being pushed but rather from the increased fuel demand and how quickly the boost is ramping...I've seen the stock tune do this..I've said this before but the fuel system stock is pretty strong but hates to be ramped on
When you get boost spikes the fuel system has a hard time keeping up due to reaction time and not due to flow limitations..Control the spike then you can control the pressure dip....With in reason or barring a mechanical problem.
ALso this was in 50 degree temps with IAT's being lower than 100 so I thought this looked decent.
There was a small dip in the multigear log... LoL... so near perfect :-P
But in the email I sent him I believe I said it was a very well done tune... didn’t know it was yours. Otherwise I wouldn’t have been so nice ha!
Haha yeah I know it's a tough crowd SBS all good...But I modified the post. I'm still calling the fuel pressure perfect...The ramping of the boost will cause a small dip but I won't say due to fuel flow limitations....I've seen it in stock logs...I could use more throttle control to help but I don't see the need for that when pressure only dips to 1850 psi for less than a second.
AJP turbo said:
Haha yeah I know it's a tough crowd SBS all good...But I modified the post. I'm still calling the fuel pressure perfect...The ramping of the boost will cause a small dip but I won't say due to fuel flow limitations....I've seen it in stock logs...I could use more fuel pressure to help but I don't see the need for that when pressure only dips to 1850 psi for less than a second.
Hell I have stock logs showing bigger dips when it’s cold...
Very nice looking datalogs, his car I bet runs like a top.
Can’t help but poke the bear a little..
Thanks to everyone! To prevent any fuel related issues god forbid I run into some bad gas , what's the best thing to monitor ?? OAR? I should be able to see OAR value on the x4 without plugging in my laptop correct? Havnt tried that yet
Knock and OAR are your best bet for monitoring fuel quality.
Both can be monitored straight from the SCT device screen when plugged in.
