How do different ELM adapters stack up re: data rates?
Here you go:
To QUOTE:
Tested OBD-II readers with Android version
aol
July 2013 edited January 17 in General
I've acquired some readers to test the new OBD-II feature on Android. The data rates are for one channel only. Here's the list of tests so far.
- OBDLink MX Scan Tool
Seems to be a very fast branded device with proper product support. Data rate very fast at 30-40 Hz. Best available reader!
http://www.scantool.net/obdlink-mx.html
- OBDLink LX Scan Tool
Similar to MX, but much cheaper. Read the specs to figure out which one to buy.
- Car-Pal:
Data rate 3-4 Hz on BMW e91 (RaceChrono v2.30)
- OBDkey v1.1:
Data rate 5 Hz on BMW e91 (RaceChrono v2.30)
- OBDkey v1.3:
Data rate 8-9 Hz on BMW e91 (RaceChrono v2.30)
- HHOBD Advanced:
http://racechrono.com/photos/obd/IMG_20130726_131424.jpg
- China blue "elm327" mini:
Data rate 30-40 Hz on BMW e91 (RaceChrono v2.33).
This is probably not a genuine ELM, but it claims to be ELM327 v1.5. Data rate it can achieve is simply amazing. This is an unbranded device, so if you buy one, remember you might not get same hardware as I did.
http://racechrono.com/photos/obd/IMG_20130726_131431.jpg
- China white "elm327":
Data rate 15-20 Hz on BMW e91 (RaceChrono v2.33). This is probably not a genuine ELM, but it claims to be ELM327 v1.5, also it reports a fake Bluetooth address. This is an unbranded device, so if you buy one, remember you might not get same hardware as I did. (Note: Had some problems with protocol checking but will fix for v2.45 beta)
http://racechrono.com/photos/obd/IMG_20130726_131445.jpg
- China black/blue "OBD Diagnostic Interface"
Didn't test the data rate, but works (RaceChrono v2.33). This is rather sizeable receiver with five blinking leds...
http://racechrono.com/photos/obd/IMG_20130707_140639.jpg
NOTICE: The test BMW I'm using has CAN bus, hence the faster polling speed. It seems older cars, such as my other test car, with no CAN bus seem to be limited data rate around 5-6 Hz maximum.
