StinkinLinkin13 said:I'm in the process of returning to stock. Technically I'm still under Lincolns 70k mile drivetrain warranty. It was also a certified used car... So hopefully they take care of it. My only concern is the flash count if they decide to look.
802SHO said:Damn man I'm really sorry this happened! LMS tune right?
StinkinLinkin13 said:802SHO said:Damn man I'm really sorry this happened! LMS tune right?
Not running LMS tune. Not gonna name the tuner as a lot of you may already know... But I don't think it was their fault and won't lay blame. I actually was datalogging when it happened and nothing out of the usual in the log. It was still a relatively mild revision.
SuperPete said:Crazy question:
Looking at the Turbo Waistgate shaft I noticed it has allthread and lock nut, meaning the travel and zero point of waist gate can be changed and calibrated.
Is it possible some of the turbos like my and some other guys with low boost are not calibrated and not closing all the way?
SuperPete said:I am not dropping my downpipetoo much work.
Can I do same thing without dropping it?
Can I put 20PSI, close waistgate, put a mark on the shaft how far it went in, then undo C-Clamp, more it by hand and see if it's traveling pass them mark?
Is that possible?
SuperPete said:I am not dropping DP, I still have nightmares of me putting PPE DP's in few months back, LOL
I got this, I have work cutout for me on Friday night, can't wait...
I will apply 20PSI to the actuator, get under the car, remove C-clamp, disconnect the shaft from the arm and see if I can move arm anymore to close position, if I can I will adjust the set-nut to that and call it good.
Thinking about it, you dont really need 20PSI, stock turbos are about 12 at max?
So even 15PSI will do the job
I think that is worth a stickySM105K said:SuperPete said:I am not dropping DP, I still have nightmares of me putting PPE DP's in few months back, LOL
Starting pressure is arbitrary. Pressurize it enough for the actuator to fully engage the arm to move the flap to the fully closed position. At whatever pressure that is mark the rod. Start backing it off a psi each time and see when the rod moves back towards the starting position. From there adjust the adjustment piece to have it close fully with less pressure.
If I were you I'd temporally change my avatar and signature, you never know who's watching.StinkinLinkin13 said:I'm in the process of returning to stock. Technically I'm still under Lincolns 70k mile drivetrain warranty. It was also a certified used car... So hopefully they take care of it. My only concern is the flash count if they decide to look.
