Where to begin.. EcoHell has 45494 miles on her. I drove from NY to FL and arrived on Monday (7/12/21) with no issues. I get back in EcoHell on Tuesday around 3pm and the wrench light pops up and when stepping on the gas it felt like it was running on 3 cylinders, until around 2000 rpms and it ran fine. I immediately made a u-turn and returned back to the house. Used my scanner and didn't have any "terrain management system fault" codes. Had an O2 sensor code which I always had, just not enough to set off the Check Engine light (has nothing to do with this particular story, but just mentioning it). When I turn off the engine and open the door, the wrench light will not return unless you start the engine, go forward or reverse and actually press on the gas pedal.
Wednesday - I called the nearest Ford Dealership to setup an appointment. They were very accommodating, since I was visiting from NY. I called AAA to discuss having EcoHell flatbedded to the dealership. Everything is going as planned so far. I then go outside to smoke a cigarette standing next to the driver's side wheel under the carport (not touching or leaning on vehicle). Moments later, I hear a loud clunking noise from the wheel area..and I mean loud enough to assume the exhaust fell off the car. I look under the car and nothing..everything seemed fine.
I start her up and everything appears normal. I back out of the carport and when I press on the gas pedal no wrench light. I back up further pressing the gas and still no light. I stop, go forward pressing on the gas pedal and still no wrench light. I then take a small trip around the neighborhood to see how EcoHell is performing. Keep in mind the speed limit is 20mph so the fastest I could go was around 40mph (which was for testing purposes). EcoHell is running like she did before..all is fine.
I am posting this because I never had the wrench light come on. I never had any of my vehicles act like this where it clunked and drives as if nothing happens. What are your experiences with the Terrain Management System Fault - wrench light?
Bill
Bill
