SHOdded said:with cabin heat on MAX, yes. Normally a few drive cycles and it should stabilize. If it does not, you will have to burp it. A Lisle SpillFree Funnel is helpful in these stubborn situations.
SHOdded said::thumb: :thumb:
SHOdded said:Don't have an SHO.
Oh, and be careful taking the bolts off the housing. They strip easily. LME does not supply the gasket for the tsat, so you will need to reuse the old one. Note where it goes on the tstat. The nipple/vent should be in the 12 o clock position when installed.
MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
If so, there are shop manual pages for the t-stat install and bleed procedures on this thread (reply #6): http://www.ecoboostperformanceforum.com/index.php/topic,7094.0.html
Assuming the parts are the same, make sure you get the o-ring installed in the correct order.![]()
18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
Nice good find, reishe has on their website that our cars don't need a bleed after thermostat install. The system automatically degasses itself. Refill coolant and go then .
MiWiAu said:18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
I experienced a little “gurgling” on mine after tstat swap, so I did a little more in depth bleed and it went away. YMMV.
18SHO said:MiWiAu said:18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
Really? Describe in depth bleed if you don't mind
MiWiAu said:18SHO said:MiWiAu said:18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
It’s a pdf attachment in the thread I linked above. In addition, I parked on a steep incline in an attempt to get the degas bottle to the highest point (hoping any air would evacuate easier).
I wouldn’t sweat it too bad. Keep the degas bottle topped off and you can probably just drive as normal. If you hear weird noises, you could try to follow the procedure to rectify.
18SHO said:MiWiAu said:18SHO said:MiWiAu said:18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
That link for bleeding doesn't work unfortunately only the install of thermostat
MiWiAu said:18SHO said:MiWiAu said:18SHO said:MiWiAu said:18SHO said:MiWiAu said:Is the t-stat install process the same on '18 models as it was on earlier Ecoboost? I've been out of the loop for a while.
Hmm. I opened the attachment just before my prior reply and it worked for me. Maybe the mods can help?
